Travis M - Clutch
mshultz
02-18-2006 18:04:52
Do you know if the DC clutch on e-bay would work in a Case C? Need one.
Thanks
Travis M
02-18-2006 18:21:19
 Re: Travis M - Clutch in reply to mshultz, 02-18-2006 18:04:52
I'm not sure if it will work in a CC, I would guess that it would, but maybe someone else will know for sure. I would guess it would though
Doug Boll
02-20-2006 05:10:52
 Re: Travis M - Clutch in reply to Travis M, 02-18-2006 18:21:19
Clutch will work with the matching flywheel for the particular clutch design, From 1929 until mid 40's Case used the same clutch, then changed until 52 when live power came out. The later input shafts have shorter splines so a later clutch in an earlier D series or a C, CC the throwout bearing rides on the splines instead of of smooth part of the shaft. I am doing this on my CC with no problems yet.
