450 gas c-281
dogonewild
02-17-2006 20:21:34
lookin at a 450 gas to build modified field stock.Dont want to spend a fortune in the engine but some cheap tricks would be nice. Wouldnt mind head and cam work but bore and stroke dont fit the bill. Want to keep it 281
ChadS
02-19-2006 07:12:08
 Re: 450 gas c-281 in reply to dogonewild, 02-17-2006 20:21:34
I can get ya 70+ out of a 281, the +HP is what else you do to the head when you have it redone. kits start at $950. All new parts, and no boring involved with 264 and 281 blocks. Ill be at [email protected] ChadS
ChadS
02-19-2006 07:15:08
 Re: 450 gas c-281 in reply to ChadS, 02-19-2006 07:12:08
OR www.thetractorshop.com ChadS
Mcred
02-18-2006 12:13:25
with a 281 you already have a good head and cam vs the M put of course you can always do more to them if desired, putting a toughfer spring in the governer will help the rpms also. Having the moter set at about 2400 rpms wount hurt it any eather, Iv seen stock M's and 350's run at 3000rpms and have not flew apart..... .yet.
Justin
supermpuller
02-18-2006 15:01:35
 Re: 450 gas c-281 in reply to Mcred, 02-18-2006 12:13:25
1920 rpm's is 20% over stock rpm's of a M, thats all most div 1 - 3 allow most pulls only allow 10% over or 1760 rpm's, a 450 cam , lp intake and exhaust a little head work will wake a old M up.
Mcred
02-18-2006 16:02:18
 Re: 450 gas c-281 in reply to supermpuller, 02-18-2006 15:01:35
ok I did not know you had them rules around here anything goes as long as it looks stock your fine but the rpm thing sounds right because I seen them checking that at Sigorney IA last year, they were only allowed 10% over also. Justin
B BARENIE
02-17-2006 22:00:01
NO CHEAP TRICKS !
PUT YOUR MONEY IN A WROTH IRA !
SELL THE TRACTOR AND HAVE SOME PIZZA !
