SINGLE CUT VS. V CUT TIRES
Eastcoastpuller
02-17-2006 11:24:34
Looking for opinions on the single cut tire vs. the v cut tire. witch tire has worked best for you
I will be pulling on a hard track. I know there has been someone who switched form one to the other and can say witch tire got the best traction. Just trying to do it right the first time. Thanks in advance David tires size 20.8 x 38 firestone
Eastcoastpuller
02-20-2006 07:00:40
 Re: SINGLE CUT VS. V CUT TIRES in reply to Eastcoastpuller, 02-17-2006 11:24:34
running in hot farm class, as fast as I can pull it and we run 11500 lbs on up. thanks for the help.
dogonewild
02-17-2006 20:31:04
What class you pullin in? Any speed limits? Limited RPMs? Masive amount of power and alot of wheel speed V-cuts work best most of the time.Slower speeds ,slower gears need a little more bar left so a sharp single works good
