JD A hp
Dane in PA
02-16-2006 19:32:36
I'm taking my 1952 A to a guy who has a dyno this weekend. what PTO hp can I expect and how does that equate to drawbar hp? I'd like to know how much power i'm actually putting out at the tires. thanks
Mike n Mo
02-16-2006 20:08:32
 Re: JD A hp in reply to Dane in PA, 02-16-2006 19:32:36
Not trying to be sarcastic, but without knowing anything about your tractor and what's been done to it I would say you should see anywhere between 20 and 100 HP. I've seen them at both ends of the spectrum. If you have a typical A with .125 over M&W style pistons, a cam that isn't worn out (including bearings), properly adjusted valves, properly adjusted carb and timing, valves sealing properly, no blowby from rings, 40 HP give or take a couple. When I put my 60 on the dyno the 1st time I thought it had always run pretty good, but it only had 30 HP @ 540 PTO rpm's. Half an hour later with some tuning I had 42 HP (only mods from stock are .125 over M&W's). I think the Nebraska tests would rate drawbar HP at 75 percent of PTO HP, but not sure of that info.Good luck, Mike
Mike n Mo
02-17-2006 08:21:13
 Re: JD A hp in reply to Mike n Mo, 02-16-2006 20:08:32
The 75 percent drawbar hp as compared to PTO hp I mentioned earlier is incorrect. Rated drawbar HP is 75 percent of max drawbar HP in the Nebraska tests. The 1947 Nebraska test showed 34.14 max drawbar HP for a gasoline A
Mike n Mo
02-17-2006 06:46:49
