Oliver 60 pistons/sleeves/bearings?
johndear
02-14-2006 19:59:09
Got an Oliver 60 severly worn out and in need of larger pistons to fill the holes. Any ideas on sleeves and pistons that can be made to work? Would it be possible to use 66 sleeve/piston overbore kit and bore the block to accept the sleeves? Is the compression height the same or would I have to come up with a different rod? I know the 66 has more stroke so I assume the rods are a different length and the pin is probably higher in the piston. Being lazy and trying to cut down on research to find a piston that cam be made to work. What about rod and main bearings? AGCO still carry any parts for this motor or is it a total orfan now?
Thanks,
