dyno
Jim 52g
02-14-2006 14:31:56
does anyone know where to buy a dyno or even know how to make your own. I'm just needing something to put tractor under a load to fine tune the timing and carb load adjustment. Thanks
mshultz
02-16-2006 10:39:59
 Re: dyno in reply to Jim 52g, 02-14-2006 14:31:56
we tune on a manure pump - it can sit there at an idle and run, but the harder you pump the harder it pushes back. Not perfect, but a constant load to give you an idea of what it will be like down the track. Tune to the most RPM's at full throttle with carb, ignition timing, tappet clearance, etc.
Pullin
02-14-2006 15:09:04
I have a M&W P400 Dyno I would sell, If interested give me an email
Jim 52G
02-15-2006 12:16:38
 Re: dyno in reply to Pullin , 02-14-2006 15:09:04
Hello, what are you wanting for the dyno and what state are you in? thanks
