Running H on Alky
Farmall H Pulle
02-13-2006 18:34:59
Can some one please give me the steps to run my h on alky. Also does enyone know where i can get some at. I live In Brookville, IN.
Thanx Miles
ChadS
02-16-2006 08:30:18
 Re: Running H on Alky in reply to Farmall H Puller, 02-13-2006 18:34:59
Miles, why do you want to run Alky? ChadS
Gary Baker
02-14-2006 05:53:38
Sounds to me like you need to seek professional help with your CRAB problem.
WILDMAN H
02-14-2006 03:49:57
BETTER MAKE SURE RULES WILL ALLOW ALKY.
Cody
02-13-2006 20:12:42
Get your carb tuned in on gas and double the jet sizes. Alcohol isn't a touchy to tune as gas, but it takes twice as much to run an engine. It will pick up approx. 20% more power throughout your whole rpm range. Be sure to run a top lube in the alky and drain your fuel system if you plan on letting the tractor set for a while. Oh, you can't see Alcohol burn, you can just feel the heat, so be careful.
Eric W
02-13-2006 18:55:08
I heard that there was a pretty hot SUPER H down there that has ran alcohol before.
