John Deere valve question
REDJD
02-13-2006 08:54:45
I am in the process of rebuilding a 1951 model A John Deere. When I took the head apart I found that the intake valves were worn out, so I bought new ones.Someone told me if I wanted more power to have the machine shop install bigger valves.
If I do this can I use the 2 new intake valves on the exhaust side (since they are bigger)and put bigger intake valves in?IF I can't do this I will have wasted 50 bucks on the 2 new valves,unless I just go with the stock valves.Thanks
JDBert
02-13-2006 10:33:21
 Re: John Deere valve question in reply to REDJD, 02-13-2006 08:54:45
Unless you've done quite a bit to your motor I would not install bigger valves, go with what BushogPapa tells ya.
BushogPapa
02-13-2006 09:47:10
The Exhaust valves are made from different materials, to stand higher heat.. Proper tweaking of the Valve shapes, and the same areas under the seats..and matching the ports and port clean-up ..as well as cleaning up and polishing the combustion chambers will give you more, with less expense...
Ron..
