M M Side shields
Little Yellow D
02-12-2006 10:49:00
Has anyone built a set of side shields for a MM U and if so the left side appears to be a little tricky with filter and dist. Will take any advice thanks Mike.
Little Yellow Dude
02-12-2006 16:51:37
 Re: M M Side shields in reply to Little Yellow Dude, 02-12-2006 10:49:00
Thanks for the info. I saw one other that the solid sheet was cut out for the filter and distb. I might just square the left side out to meet the filter Thanks! Mike.
minnie ub
02-12-2006 13:58:49
WE DID THE MEASUREMENTS AND HAD A SHOP THAT DOES ALOT OF ALUMIUNM WORK DO OURS. WE MADE BOTH SIDES MATCH. ATTACHES TO THE SHEET METAL ON TRACTOR THEN THE WHOLE SHIELD COMES OUT TO CLEAR FILTER AND DIST. OURS IS ON UB BUT WOULD BE THE SAME.
