Tread height for cut tires?
JD720
02-12-2006 05:58:09
What would be a good tread height to shoot for on 18.4 X 38 super all tractions on 18`` rims ? They will be going on a pretty healthy G John Deere.I think most of the tracks are clay that I will be pulling on. Thank`s
Pull a 4010
02-12-2006 10:57:49
 Re: Tread height for cut tires? in reply to JD720, 02-12-2006 05:58:09
I would say about 3/4", that is what I cut mine down to and they hook up well. It also leaves a little tread left in case I need to sharpen them back up. That's what works for me.
Justinn
02-12-2006 21:18:52
 Re: Tread height for cut tires? in reply to Pull a 4010, 02-12-2006 10:57:49
I agree, I think 3/4" would be a good number to shoot for. It'll work well in that weight range you're in.
Justinn
02-12-2006 07:27:08
What weight class? The heavier you go usually the less tread you'll need.
JD720
02-12-2006 13:55:17
 Re: Tread height for cut tires? in reply to Justinn, 02-12-2006 07:27:08
I will probably run in the 5500 to 6500 classes 4 Mph. and 6 Mph. I would try to go lighter but it seems pretty hard to keep the front end close to the ground with the Deeres being so light up front. Thank`s
