how do farmall 230s pull????
T.r.y.
02-09-2006 19:01:12
I have one I would like to set up a little for pulling. Wondering what weight class is best, pulling hitch, tires?? thanks
CLIFF S
02-12-2006 17:26:52
 Re: how do farmall 230s pull???? in reply to T.r.y., 02-09-2006 19:01:12
Check out NATPA .com and look at there results in 3250 and 3500 lb Div 3&4 classes Gene Sellers 230 is one of the toughest 230s that you will ever see pull aneywhere!
FatRedneck
02-10-2006 04:08:22
my brother has a farmall 230 that hasn't been beat in 3 years. we pull at about 10 tracks in northern maryland. he pulls the 3500# stock class. the hitch should have 2 sets of holes in the up and down adjustment, you need to put the hitch at its top setting, which here is an inch too high, but if you let air out of the tires that should alleviate that problem. his has a wide front end, so you might have to put weights on the front. I hope you don't have a fast hitch, cause they dont pull the same.as far as tires go 13.6's in the firestone field and road's do the job just fine. hope I helped.
t.r.y.
02-10-2006 12:21:56
 Re: how do farmall 230s pull???? in reply to FatRedneck, 02-10-2006 04:08:22
Did you ever pull at maxon dixon or at cecil county fair?
t.r.y.
02-10-2006 05:57:39
what weight classes do you pull in?
Kip[UT]
02-09-2006 19:41:58
We have a couple guys in our club that do OK w/ a C & Super C. The 230 should do as well or better.
