U or UB
Lightest MM
02-09-2006 10:04:48
Which tractor is the lightest, which is better to pull in stock type classes. Maybe like to pull in 4500 and up.
LW
02-10-2006 07:06:03
 Re: U or UB in reply to Lightest MM, 02-09-2006 10:04:48
I did a U that weighed 3880 without driver, Driver and a 100lb weight in the 4200 lb class.
Mopower
02-10-2006 04:19:24
The old stock 1947 I had weighed 5350 with my 150 pound rear on it. It had cast centers and a PTO but not much else. I am working on a 1946 now for 4500. It shouldn"t take much. I might put on some UTS or G housings and axles. You don"t have to run the tranny full of oil either. 5 gallons will do for pulling. A UB can be 4500# but it"s a bit more work. By the way, I know a few fellas attempting a 3500# UTU.
Bencie
02-10-2006 14:15:06
 Re: U or UB in reply to Mopower, 02-10-2006 04:19:24
I have a 48 "U", starter, gen., & battery are removed. Hand starting with crank, it has a mag on it. Of corse the pto & belt pulley drive are gone too. It has the one piece cast rear wheels. how much difference in weight are they compared to the two piece rear wheels? It now weighs 5300 with me on it.(180lbs) How much more can I loose with alum pan & lid? Also tires are 15.5 151's
mo4xdadad
02-09-2006 16:16:47
A U will be easier to get into 4500. You need to strip everything that doesn"t apply to pulling. Every cover replaced with fiberglass or aluminum, and maybe a little more depending on driver size and tires. I have pulled two in 4500 in the past, and they looked very complete and not all chopped up. Email me for more ?"s. I may have some stuff to help you too.
ejr-IA.
02-09-2006 12:16:32
We have both .Do you like a hand clutch or foot clutch?I like the foot better you can let the front end down gentle if you get in the air.Hand snaps out and down you come.We have one U with m5 blocks and 4210 heads,One UB with the same and another UB with stock blocks and 4206 heads.We pull them in div 1and2.You will have to strip it down to get to 4500.
Bencie
02-09-2006 14:37:29
 Re: U or UB in reply to ejr-IA., 02-09-2006 12:16:32
What's involved to make 4500 with the "U"? Is it a must to use standard axles and housings?
Brian F. Williams
02-09-2006 17:55:05
 Re: U or UB in reply to Bencie, 02-09-2006 14:37:29
I used to pull a '47 UTU. Believe it or not. I could pull with a farm fresh tractor, fenders and cast wheels and all. The old girl weighed about 4450. Most people I pulled against were sceptical. I don't know why it weighed so little. I even had hydraulics on it.
Brian F. Williams
02-09-2006 18:02:05
 Re: U or UB in reply to Brian F. Williams, 02-09-2006 17:55:05
I'm sorry I spoke out of line. It's been awhile ago. Should be 5500. Sorry.
