tire info ground foot print 14.9 verses 14-34
sm-53
02-08-2006 16:28:32
14.9-38
15.5-38
14-34 straight old 14.34
all tires on 14" width rim !!
does anyone know the actual width of the tire ?
outside to outside ! on the rim !!!
also foot print what is the foot print pressure
14-34 verse's 14.9-38-15.5-38 Yes the old 14-34
all info would be appreaciated !!!
Sambo
02-09-2006 17:23:51
 Re: tire info ground foot print 14.9 verses 14-34 in reply to sm-53, 02-08-2006 16:28:32
It could be any of those sizes those are old tires and some tires they wouldn"t have the size of them but the size of the rim they go on the 14x34 is the size of the rim they go on they could be 15.5 16.9 or something else. To get a rough estimate measure across the tread with a measurin tape These are good tires because there larger than what they say and you could put them on a tractor in a class that uses smaller tires than them and get away with it.
Lamont
02-09-2006 10:20:59
If I'm not mistaken, the old 14x34 is the same as the newer 16.9x34. In fact, most 16.9s say 14-34 in smaller print on the tire.
SM-53
02-09-2006 15:13:55
 Re: NOT THE ANSWER I'M LOOKING FOR-PLEASE REPLY in reply to Lamont, 02-09-2006 10:20:59
WAS THEIR A 14.9-34 EVER BUILT !
IF SO WHERE COULD THEY BE FOUND !!!
PLEASE DON'T LAUGH !
Lamont
02-09-2006 18:57:40
 Re: NOT THE ANSWER I'M LOOKING FOR-PLEASE REPLY in reply to SM-53, 02-09-2006 15:13:55
Not that I know of.
Dave in MN
02-08-2006 16:36:45
check www.firestoneag.com This should have the info you want
