Burn't carbon center in dist.cap
Dennis Andres
02-06-2006 20:04:34
I have a 60 JD with pertronix ignition and an accel coil. What could be causing my cap to burn the center carbon down to the brass? I put a new cap on when I installed the ignition.
ChadS
02-11-2006 06:31:39
 Re: Burn't carbon center in dist.cap in reply to Dennis Andres, 02-06-2006 20:04:34
Too much voltage going thru the coil wire tower. Put a resistor on the power wire for the coil, problem solved. Some caps are not as good as we expect,, Chad
