pressed steel wheels
jd plowboy
02-06-2006 04:08:09
does anyone have or know where i can get a set of 14x38 pressed wheels with 14.9x38 or 15.5x38 tires on them. put ad on yesterdays tractor with no luck. putting them on a oliver 88
770
02-07-2006 19:03:23
 Re: pressed steel wheels in reply to jd plowboy, 02-06-2006 04:08:09
Barrick's tire is in PA. Newville I believe. They sell tractor rims.
Brian Arnold
02-07-2006 14:45:27
Hey JDPlowBoy call me I know where there is a set in SC cheap 843-821-1874.
mike
02-07-2006 09:16:29
not what you are looking for but I have 2 pair of 16 x 34 9 bolts w/ the heavy center in them. came off a 7520 that blew a turbo and roasted itself. also have a set 20.8 34s firestone 151. tired of looking at the stuff. upstate NY on the vt border.
mike from tales
Charles Ostwald
02-06-2006 18:46:41
I have two new 14x38, nine hole, pressed steel rims for $500.00. I have two 15.5x38, deep tread, Firestones for $150.00 for the pair. They have about 30% tread. If you're interested, let me know. Thanks -
Charles Ostwald
02-07-2006 16:17:25
 Re: pressed steel wheels in reply to Charles Ostwald, 02-06-2006 18:46:41
I am located in Northern Michigan. I am fifteen miles south of the Mackinaw City, which is at the northern tip of the lower Pennisula at the Straits of Mackinaw which joins Lake Michigan and Lake Huron.
mshultz
02-07-2006 04:16:07
Where are you located? Probably too far away for me, but I'm looking for both rims and tires that you have if in good condition. Located in PA.
jd plowboy
02-07-2006 04:25:18
 Re: pressed steel wheels in reply to mshultz, 02-07-2006 04:16:07
i am in south carolina. the tractor has pressed steel on it but on is orignal and one looks like it is off a newer tractor. the offsets are different and one is wider than other. this is why i need a set of wheels.
champspa
02-06-2006 15:28:23
saw some at Miller Tire . com
