Clutch for farmall h puller
Farmall h pulle
02-05-2006 15:50:16
Does enyone know where i can get a good clutch for pulling a farmall h. Aslo how much are they? Is there a way to adjust the clutch on a farmall H?
Thank You,
Miles
Andy Bolsen
02-07-2006 04:55:54
 Re: Clutch for farmall h puller in reply to Farmall h puller, 02-05-2006 15:50:16
I changed the clutch in my '47 H last summer. I used an Allis clutch from a WD. The splines are the same but the clutch surface is wider. I used a replacement pressure plate with stiffer spings for an H. If your flywheel surface is in good shape it is very easy way to get more clutch surface at low cost. I also changed throwout bearing. The first time I hooked the front end came up for the first time ever. I had more slip than I knew before. AJB
Mike S 806/H
02-06-2006 17:51:48
Fort wayne clutch and drive, (260)484-8505,
ChadS
02-07-2006 06:58:22
 Re: Clutch for farmall h puller in reply to Mike S 806/H, 02-06-2006 17:51:48
How"s your 460 comming along? Mine is running pretty good! ChadS
Mike S 806/H
02-07-2006 17:41:48
 Re: Clutch for farmall h puller in reply to ChadS, 02-07-2006 06:58:22
Hi Chads, All I have done with it is drove it out of the shop and put it in the barn, Had to fix oil leaks on my 400 Diesel and do a T/A, Engine rebuild,and put all new o-rings in the hydraulics on my 450, when thats done I have to get the 1066 in to do the injection pump (governor's bad), When it warms up I get the 460 out, I will get a picture of it and post it on here,
AO
02-06-2006 04:45:57
Contact Southeastern Tractor @ 1-888-658-7171. They are in Jefferson,SC
WILDMAN H
02-06-2006 04:18:08
FIND A 350 FLYWHEEL AND CLUTH, TAKE IT AND HAVE HEAVY SPRINGS PUT IN PRESSURE PLATE AND DISK WITH 6 BUTTONS.
