Massey 44 up to div IV
Kevin
02-03-2006 13:10:52
I am trying to get my massey 44 into enhanced classes. Right now i have 4-1/2" internation truck piston from their 534ci v8. Head has decked .250 and it has 427 chevy valves. Just wondering what i can do to improve on this setup to get more power for div IV? I feel i need to get some more stroke in there? Anyone know what can be done with what i already have in there? Next question is what size tires should i run?
Masseypuller
02-08-2006 18:52:47
 Re: Massey 44 up to div IV in reply to Kevin , 02-03-2006 13:10:52
Sorry, but you won"t be able to compete in Div4 with only a 4.5 inch bore, no matter how big of a stroke that you install. For the "enhanced" classes I would stroke the crank to either 6" or 6.25", depending on whether you are willing to (or even can) machine the pistons AND counterbore the cylinder head to accept the piston protrusion with the new stroke.
If you have room to cut an 1/8" off the top of the piston and still have ring land, then stroke to 6.25". If you have no room to mill the top of the piston down, then stroke to 6". Either way, you will need to counterbore the head 1/4" for piston protrusion clearance. I would only suggest counterboring a head that has not been radically surfaced...
Currently, we are running 5" X 7.5" with a full water jacketed block! The induction system has a few bugs to be worked out though...
unknown puller
02-05-2006 11:26:03
I'm not a maseey man but is your bore the max it can go like in to the water jackets and filled full of grout. I'd think youd be able to get at least a 4-3/4 bore. Send the crank out and have it sroked should get 6-1/2. For tires you would have to run 18.4 just like every body else in those classes. I personaly are dropping out of Div. 4 and are going to Div. 2 plus or Div. 3. It costs way tomuch money to compete in div. 4 Its all about how fast you can go and how much horse power you make.But good luck at trying and remember its also about having fun !
gee
02-05-2006 06:02:16
i have a set of jahns pistons 4.5/8 for a 44 i would sell. Email me.
Kevin
02-03-2006 18:47:03
When i bought the tractor i was told they are international. Sorry, dont have any to sell. Tractor only came with what was in it.
Doug Boll
02-03-2006 13:45:51
Are you sure those pistons are not from a 534 Ford, they are 4 1/2, If they are Ford got any to sell? Don't know what you can stroke a massey but for div. 4 I would put in all I could!
