Need advice on 291 I.H. Gas motor......
migraine
01-31-2006 08:53:53
Took the motor apart on Sat. and found no 2 cylinder had been bored and had oversized sleeve in it. So now don't what to do already have the head redone with new guides and intake valves. Should I rebore the whole block and make it into what a 301 or 310 or rebore and use oversized sleeves with same bore. We were going to install this into a 460 farmall and wondering how much hp that 460 rearend will stand if we put heavy duty TA and clutch in it? Anybody got sources for this overbore project or some used parts laying around or tell me where to look. Thanks for any and all ideas. Migraine P,S. Will this head bolt right on to 263 cu in 560 block?
ChadS
01-31-2006 15:50:13
 Re: Need advice on 291 I.H. Gas motor...... in reply to migraine, 01-31-2006 08:53:53
If the overbored sleeve is not beyond 3-13/16 bore, then you can go with a 301,, maybe even up to .060 over,,, Seen guys put the 501 red diamond in the 350 rear ends,, seen one even in a H, dont know if they held up or not,,, whats the bore on #2? CHad
migraine
01-31-2006 19:52:27
 Re: Need advice on 291 I.H. Gas motor...... in reply to ChadS, 01-31-2006 15:50:13
Thanks Chad. I appreciate your constant source of practical and helpful advice. I will make a decision tommorow after thinking all the options. migraine
ChadS
02-01-2006 09:58:07
 Re: Need advice on 291 I.H. Gas motor...... in reply to migraine, 01-31-2006 19:52:27
I think, what to watch would be the constant mesh gears in these rear ends, under a hard pull, they may take a tooth or 10 off it,,, Have you ever considered a limited slip for you turbo 460?? Chad
migraine
02-01-2006 20:05:21
 Re: Need advice on 291 I.H. Gas motor...... in reply to ChadS, 02-01-2006 09:58:07
I have thought about the limited slip but don't know how much it would help me. The rear end had just been gone through with new seals and bearings shortly before I gutted it and made it into "Migraine". I really don't have much trouble with one wheel giving out first but again I'm still running in High third gear at 3200 rpm's. I am looking at going to 16.9-38 tires on it and should pick up about a mile an hour with that putting me at 10.5 mph. This other 460 I have is just an old farm tractor that I picked up for nothing so trying to decide now if i want to put 1200 dollars in the motor plus the overhaul kit, line bore, rebuild carb and jet out and new clutch and heavy Ta. Maybe I'd still have a pretty cheap puller but maybe I should just take the head and put it one of my 560's and cut my losses here. The machine shop quoted me a hundred bucks a hole to bore out and match up to whatever sleeves and pistons I come up with plus the cost of the line bore and press the sleeves in. Sounded high to me but maybe that's where the market is now. Just don't know what to do! Any more advise from a guy who's been there ? Thanks Migraine
ChadS
02-02-2006 06:18:08
 Re: Need advice on 291 I.H. Gas motor...... in reply to migraine, 02-01-2006 20:05:21
I think I would go find a better engine,, use the 291 for parts. You can find another combine engine,, those usually are in mint condition VS the tractor engines. Go find ya a good running 301, and overhaul it. I took my 263 out of a 403 combine, and when I tore it down to build, found that the parts were as good as new. I did a re ring, and rod bearings, head totally rebuilt, I think I had less than 500 in the whole thing,, So if you buy a engine for 500, thats in better shape, youll save the money on boring it out, at least 600 (100 a hole) then you have to buy pistons!! I bet, you would have over 1200 in boring the old 291 out,, then what if that sleeve gives you fits???,,,,, JMHO,, Chad
