tires
johndeereman
01-31-2006 08:33:05
going to get new tires for my john deere b what would be the best to pull on hard packed clay with long bar long bar or long bar short bar
300
01-31-2006 10:11:27
 Re: tires in reply to johndeereman, 01-31-2006 08:33:05
if you are not running cut tires the only real choice is Firestone Field & Road 23degree long bar/long bar,also you want to run the largest tire that your rules state.The larger the tire the more rubber you put to the ground & that equals more traction.
Super Lurker
01-31-2006 10:28:31
 Re: tires in reply to 300, 01-31-2006 10:11:27
Brand new tires are too soft and the cleats are too tall. The tall, soft cleats will "roll" on you and spin out. Usually the best tires to pull with are old, hard, 3/4 wore out tires that are the largest your rules allow. Each track is different, so your mileage may vary.
