radial tires
jimmyjoe
01-31-2006 04:47:28
Why cant we pull with radials
kanuread
02-01-2006 21:37:11
 Re: radial tires in reply to jimmyjoe, 01-31-2006 04:47:28
The rules state,"bias tires".Pretty plain,Huh?A radial has a larger footprint,Hence the 18.4 38 BIAS, max tire size rule.As for the HotRods,If you can't run with the big dogs stay on the porch.Would this be why there are different classes?
jimmyjoe
02-02-2006 16:37:12
 Re: radial tires in reply to kanuread, 02-01-2006 21:37:11
depends on what the tire size is, a 13.6 is smaller than a 18.4,, Duh?
kanuread
02-02-2006 19:31:03
 Re: radial tires in reply to jimmyjoe, 02-02-2006 16:37:12
Boy you're sharp as a tack and twice as flatheaded.LET'S SEE,is 13 less than 18?Why yes it is, so that WOULD make it a smaller foot print, you moron!!The POINT is: a radial tire has a larger footprint than the SAME SIZE bias tire.DUH.
jimmyjoe
02-04-2006 19:03:46
 Re: radial tires in reply to kanuread, 02-02-2006 19:31:03
hey jerk, not everyone runs 18.4, i myself run 13.6, and do just fine, u want everyone to run 18.4 do u , well it is true thats maximum size, then therefore a 13.6 radial is equal to your 18.4
Lamont
01-31-2006 17:00:53
Are you implying that not allowing radial tires is BIASED?
jimmyjoe
01-31-2006 18:27:49
 Re: radial tires in reply to Lamont, 01-31-2006 17:00:53
Yes
jimmyjoe
01-31-2006 16:29:45
But neither were all these hotrod super fast tractors, its ok to update with thousands of dollars in the engine, i dont think they were available before 1960 either, so why is that fair
Kip[UT]
01-31-2006 07:03:29
The obvious answer is that your club rules don't allow them. Our club only pulls antique or classic classes, [nothing newer than 1960]. So radial tires are out of character for these classes, not to mention that radials are not available in many of the older sizes, so this would give some pullers an unfair advantage if they were allowed to run them.
