J.D. late 51 Piston rods
JohndeereJerryr
01-29-2006 06:51:35
want to know if the J.D. pistons-A3282R and rod A2344R is what I have in the block now the rods are bad and the pistons are bad. wanting to know if a set of aluminum pistons and a set of A rods number A4848R will work in this block. I do know that the A4848R rods are longer than the A2344R rods but do not know about the pistons differents. Thank-you
Mike n Mo
01-30-2006 05:25:43
 Re: J.D. late 51 Piston rods in reply to JohndeereJerryr, 01-29-2006 06:51:35
I'm assuming that you have a late A from the piston P/N (gas piston for 584,000 and up). Aluminum pistons should work fine and are available from a number of suppliers. P/N A4648R rods are a direct replacement for the A2344R rods. I don't see a listing for an A4848R rod in the A or 60 parts book. Mike
Jerry Riesenberg
01-30-2006 17:51:15
 Re: J.D. late 51 Piston rods in reply to Mike n Mo, 01-30-2006 05:25:43
The rod no,. is a 4648 the serial no of the tractor is 667148, my block no. is 4820R
JDGnut
01-29-2006 20:19:31
What year is your A??? Are you sure the rod is longer??? They should be 13in from center to center... JDGnut
Jerry Riesenberg
01-30-2006 17:55:15
 Re: J.D. late 51 Piston rods in reply to JDGnut, 01-29-2006 20:19:31
My serial no. is 667148 block no. is 4820R, and conecting rod should have read 4648
