400 rebuild
Jeh
01-28-2006 04:28:25
I Have a 400 that needs rebuilt, I don"t use it for pulling but thought this board would be the place to get the info I need.
I would like to get more HP when I rebuild, what would some of you guys recomend for this. I"m not looking to build the most powerfull engine on earth, just a stronger 400. Thanks!
Jeh
01-28-2006 14:22:52
 Re: 400 rebuild in reply to Jeh, 01-28-2006 04:28:25
What size of an overbore kit should I look for?
Eric W
01-29-2006 19:30:01
 Re: 400 rebuild in reply to Jeh, 01-28-2006 14:22:52
4 1/8" will use thinner sleeves. With a little carb work should make 60 hp pretty easy.
42Farmall
01-28-2006 09:05:16
Any name brand rebuild kit will help you out especially an overbore kit. Definately put it on a dyno after you get it running. There is usually several hp to be found by adjusting the carb and timing.
