C-301 in 560
Scrappy
01-27-2006 19:59:57
Is the timming cover,oilpan, rear mounting plate, and fan the only thing needed to be changed to put the 301 combine moter in a 560? thanks, Justin
ejr-IA.
01-28-2006 09:53:52
 Re: C-301 in 560 in reply to Scrappy, 01-27-2006 19:59:57
Gas or diesel?I had to change the oil filter base too,from the aluminum to the cast one off of the tractor engine this was on the gas.But on the diesel I had to drill a extra bypass hole in the diesel block and plug one hole to use the 560 D tractor oil filter base.The reason you have to change the base is for steering shaft clearence.
scrappy
01-28-2006 17:55:14
 Re: C-301 in 560 in reply to ejr-IA., 01-28-2006 09:53:52
gas engine, thanks for info
