Looking for some 6.5 pistons
jd b puller
01-23-2006 19:43:33
Anyone have any ideas? Not really interested in making custom ones for the first motor. Anything off the shelf available? Thanks,
Pullin A
01-27-2006 05:41:18
 Re: Looking for some 6.5 pistons in reply to jd b puller, 01-23-2006 19:43:33
My dad used some later Allis farm tractor piston, I think it was a diesel but I will have to check for the exact tractor!!
jd b puller
01-27-2006 18:15:00
 Re: Looking for some 6.5 pistons in reply to Pullin A, 01-27-2006 05:41:18
Pullin A, if you can let me know what you used in the A, that would be great. My e-mail is open.
Thanks,
Glen in TX
01-25-2006 17:47:30
Early JD Ds used 6.5" . Try some of the aftermarket ones for other JDs or CATs. Check with www.egge.com or www.niagrapistonringworks.com
BushogPapa
01-24-2006 21:40:12
For a "B"..??? I do hope NOT..!! Valves are too small and the intake system will never feed them...!!
Drew
01-25-2006 09:51:51
 Re: Looking for some 6.5 pistons in reply to BushogPapa, 01-24-2006 21:40:12
A cylinder head capable of feeding an engine that size is only a CNC machine away..... ....
jd b puller
01-25-2006 18:29:59
 Re: Looking for some 6.5 pistons in reply to Drew, 01-25-2006 09:51:51
I guess pistons are just a CNC away too. Just looking for something a little less "spensive. I think the 70 PB pistons are a great idea, but they"ll be way too tall. Still lookin...
500+ cubes in a B. And if I put top cut tires on I can still pull in the stock class. WHoo-hoo.
jd b puller
01-25-2006 09:49:19
Ron, you need to think outside of the box. Yes, it's for a B. Feeding it won't be a problem.
bigmotors
01-23-2006 21:44:25
Try to find some 70 JD (TSC) Power Block - 6.500 bore pistons. Make sure to look for stress cracks.
bigmotors
01-25-2006 22:00:44
 Re: Looking for some 6.5 pistons in reply to bigmotors, 01-23-2006 21:44:25
5.750 will work. 6 inch ran into trouble.
6 1/2 - You are talking a new block.
Good Luck! Anythings possible.$$$
jd b puller
01-26-2006 03:43:26
 Re: Looking for some 6.5 pistons in reply to bigmotors, 01-25-2006 22:00:44
Now we're on the same page, bigmotors...The key is being able to build several of them, not just one. (that's what's keeping me from jumping right in. I've got all my dimensions, costs and what not and ready to go). Tooling is really expensive.
