Geting hubs off
north east pull
01-22-2006 16:13:52
Let me start out with this is not my first time of getting hubs off of a tractor. I am working on a 1949 John Deere G I have been at this now 4 weeks now and during the week have consumed 1 can of Kroll and am on my second can of PB blaster and some other good name brands followed by taping with a 5 LBS hammer .
I made a 4 inch U channel puller ( 2 welded back to back with center bolt and 5/8/ rerode to the rims 18 inches apart .) Results egg shaped washers.
Made up 4 inch square x � inch washers Results are stretched rerode like an hour glass. And flexed U chanel.
New rerode .
Results pulled thread on the rerode and out of the nuts .
Made new puller . ( 1 inch thick plate drilled holes to put 3 7/8 rodes in to hub where hub bolts go . Made center stud on plate for 10 ton porta power ram..
Results bent porta power handle .
Keeping in mined I have heated this with a big rose bud torch 5 or 6 times during this time frame. I have tried an old wife�s tail of melting in Paraffin wax to break the rust and lubricate it.
New puller # 3 10 ton air over Hydraulic this time . mixed with 18 LBS 6 foot slide hammer trying to push hub in then out .
Results broken slide hammer foot. ( exploded in to 3 pieces ). And 1 Really sore back.
Next weekend I will try driving tractor working breaks to break loose hub if that does not work the only thing left that I know of is. A. squeeze shop cat to Pee on it.
B. Have 3 or 4 Barley pops and then set on fire rolling it down A big hill towards a pond .
Unless you folks have other suggestions in mind for me to try.
Thanks, for any help Northeast puller
BushogPapa
01-25-2006 07:17:20
 Re: Geting hubs off in reply to north east puller, 01-22-2006 16:13:52
Are these hubs different than the style used on the "A" and "B"....that is, with a Steel Collar over the splined wedges..??? Can't you use 2 of the bolts in the "Pusher Holes" to push the collar off the hub..??
I have a simillar problem with a JD 630..but the Jackbolts are stripped.!!! Been working on that one for a while..maybe I will just cut the hub in pieces and put another wheel center on it..!! Ron.
Mike S 806/H
01-22-2006 21:12:57
I removed mine with a 1 inch plate, drill three holes in it and use grade 8 theaded rod, i think 5/8 or 3/4 cant remember,. put the center of the plate over the axle and the three threaded rods through the 3 holes in the hub, then just tighten up each threaded rod a little at a time and it will come off, before this I used a portapower, jacks, a little heat and it didnt move. My G had the bolt in style hubs (6 bolts hole the hub to the wheel casting) I was told I could of also cut them off so you can remove it in two pieces (halfs) and you can reuse them with no problem's
chickenhawk
01-22-2006 18:22:14
HEAT HEAT AND MORE HEAT I used torch with rose bud tip. Heat them up red hot then let them cool. Spray them with your wd should come off then
MIKE LOKAI
01-22-2006 18:15:33
ALL JOHN DEERE HUBS EVENTUALLY FREEZE,THIS IS WHAT WORKED FOR ME WITH A 620,630 AND 530.
1.CUT A FOUR INCH WELL CASING WITH OFFSET ON 1/2 HALF OF THE LEADING EDGE CORRESPONDING T0 THE WEDGE YOUR ATTEMPTING TO LOOSEN. COVER THE OUTSIDE END WITH 1/2 INCH PLATE STEEL WELDED OVER THE TOP WITH A 1 FOOT HANDLE TO HOLD THE REMOVAL DEVICE.2.JACK THE WHEEL FREE FROM THE GROUND. 3.SLIP THE DEVICE OVER THE AXLE AND HAVE A TRUSTING FRIEND USE A SLEDGE HAMMER TO JAR THE WEDGE LOOSE.4.3-5 GOOD LICKS WILL FREE THE WEDGE.GOOD LUCK (WATCH YOUR FINGERS)!!!!
north east puller
01-22-2006 17:27:37
LRN thanks but been their don that no luck and no resolts.
North east puller
LRN
01-22-2006 16:46:17
WOW, you must really love that tractor. I can understand that after all it is a G. I have had some success with driving several large chisels into the slots in the hubs while you are pulling. Don't drive them in too tight it will wedge, there is a sweet-spot. Just tighten them up and tap them in further. I have done this on several occasions and it has worked. Good luck!!!
Thanks, LRN
