Pistons needed for stroked farmall 450
MarkinIN
01-21-2006 14:15:20
I need some help finding a supplier that makes pistons for a 450 that has been stroked 1/2". It has 4 1/8" bore as well. I also need to know who makes a good head gasket that will hold at 200 p.s.i. compression.
Thanks Mark
Mcred
01-22-2006 15:08:15
 Re: Pistons needed for stroked farmall 450 in reply to MarkinIN, 01-21-2006 14:15:20
try www.thetractorshop.com and email Chad he will fix you up.
ChadS
01-22-2006 19:06:23
 Re: Pistons needed for stroked farmall 450 in reply to Mcred, 01-22-2006 15:08:15
id get that set from Barenie. Give him a call so he can get the ones he wants!! LOL! Ive got em too,, but his is all ready to go! CHad
Trkr
01-22-2006 07:08:02
If you can find any M+W farmall stroker piston kits the part # your looking for is 178. 4 1/8 x 5 3/4.
b barenie
01-22-2006 06:14:00
you said you stroked it a 1/2"
So it's 5.75 instead of a stock 5.25.
If that is the case, I have a set of arias on the shelf for sale
219.716.0467
Flogger
01-21-2006 23:27:22
If you're running a stock 4 1/8 bore with a 1/2 of stroke, you could probably mill a 1/4 of the stock piston and be fine.
Dave in MN
01-21-2006 21:07:18
Arias will make them for you. You can find them on the web.
champspa
01-21-2006 16:31:41
I use a I H gasket for a 450 at 210psi never had one blow
