how much power?
Kevin
01-19-2006 14:33:18
I was just wondering how much HP is averagly needed to pull in 3500, 4000, and 4500 div IV classes. Also how low of weight is a reasonable goal for a massey 44?
ec
01-20-2006 05:15:40
 Re: how much power? in reply to Kevin, 01-19-2006 14:33:18
33 44 same frame use a 30
MH49
01-20-2006 20:01:27
 Re: how much power? in reply to ec, 01-20-2006 05:15:40
That is kind of true. There is actualy two frames for a 44. The row crop which is *approx* 6 inches longer than the standard. It looks to me like the 30 used the same frame as the 44 standard. The 33 and 333 appear to have been a mish/mash of both.
I would NOT recomend building a 30 as a puller even if you could get it that light.
Kevin
01-20-2006 12:52:35
How does a 30 pull with the 3 speed? I was thinking of building one of them for stock classes.
Kevin
01-20-2006 13:04:28
 Re: how much power? in reply to Kevin, 01-20-2006 12:52:35
never mind, i dont know what i was thinking, its a 5 speed.
About 3500 lbs, 162 ci. Sound like it has some potential for $5000 cubic dollars and pulling it in stock classes.
Div IV Puller
01-19-2006 18:33:22
Your 44 can't pull below 4500,but to answer your question,in 35/3750 it will take 120 to do well,4000/4250 you'll need 150.At 4500 you'll run into 585 Olivers and 609 Farmalls so you'll need 180+.If you have some mechanical ability and can do some of your own work you won't need $20,000, but if you decide to spend that much you can!
ChadS
01-20-2006 04:26:20
 Re: how much power? in reply to Div IV Puller, 01-19-2006 18:33:22
Spending 20K on a stock blocked tractor,just to pull against non stock blocked tractors, does not seem like much fun. id think if 20K is what it takes, you may as well use a 33 frame, stick the 44 engine in it and pull div 5! Would not be much different than running a 88-310 engine in the 77's in 3500-4250. Do they let the 77's in div 4 run the big block 6cyl? May as well buy a tractor already built, it may save you some cash, or it could cost you a fortune if it's not up to snuff mechanicly. Tough decision. Chad
4500 lb class
01-19-2006 17:22:48
Most clubs won't let you pull lighter than 4500 lb class in Div 4. So build it big when you do. 140 hp should be enough.
AC
01-19-2006 15:16:20
Figure about $20,000 cubic dollars to do it successfully in NATPA, or about 130-180 hp in 3500lb class. You can do it with 100 and run well..Heck, I have seen 85 -90 hp tractors do well in some occasions..AC
FarmerSid
01-20-2006 04:54:31
 Re: how much power? in reply to AC, 01-19-2006 15:16:20
Did you happen to get my e-mail AC? Just wondering.
Cheers!
Sid
