More power for my JD 50- How to get it?
Tye W
01-19-2006 04:52:39
What can I do to my 50 to get around 40 hp? I need the tractor to farm with so nothing too extreme. Will a 520 head work? Thank you for any help. --Tye
LumbrJakMan
01-19-2006 06:41:58
 Re: More power for my JD 50- How to get it? in reply to Tye W, 01-19-2006 04:52:39
Paint it RED,and add 2 cylinders !! I couldnt resist .....
toot
01-19-2006 05:38:57
Fresh bore job with aluminum pistons, shave head .125, clean up head ports, bowls, 3 angle valve job, electronic ignition, dry filter conversion should get you about 35. The 520 head has spark plugs in it. If it did work, I don't think it would help any. Some people cut some of the divider out of the manifold to draw air and fuel out of both barrels of the carb. Since you are going to use this tractor, I don't know if you would want to go this route. I cut the divider out on a 70 one time - it really woke it up. BUT it sucked so hard through the intake I had to double the spring on the governor to make it open up properly.
