m coil,plugs,wires
super_m
01-18-2006 18:01:27
what kind of coil,plugs and wires are good to use on a super m.
ChadS
01-19-2006 12:34:34
 Re: m coil,plugs,wires in reply to super_m, 01-18-2006 18:01:27
Ive had real good luck with Accel super stock coils, the smaller coils, not the big huge ones. Napa, Autozone has em. Bout 30 dollars. A good 8mm wire set, or a good stock set works fine too. If your running points, use a resistor on the hot wire. Spark plugs, its personal preference, Autolites, I cant remember the number, I use Champion platinum truck plugs, #4130. The have a long electrode that reaches a little further into the cyl. make sure your ignition switch is good, older switches tend to lose contact, or cause the engine to stall if they get hot. Chad
