Farmall H
Farmall H Pulle
01-17-2006 13:47:59
Im building a Farmall H with a 3 5/8 bore and stock stroke. I got the govener and distribter reworked and the head is rebuilt. I was thinking about a bigger carb because it has the small one now. I already have the manifold for the bigger carb also. What kind of carb would work best for me. Is there enything else I can do to get some more power? How much should it have now? Also has enyone ever ran one on alchol. Thanx Miles
ChadS
01-17-2006 15:00:22
 Re: Farmall H in reply to Farmall H Puller, 01-17-2006 13:47:59
M carb, #23-25 venturi for max low end torque, jetted to match. Yeah we have ran em on alky. They run goooood! Chad
Farmall H Ben
01-17-2006 16:55:37
 Re: Farmall H in reply to ChadS, 01-17-2006 15:00:22
what manifold do you have to use to make the M carb work
JakeF
01-17-2006 20:50:58
 Re: Farmall H in reply to Farmall H Ben, 01-17-2006 16:55:37
super H -350
New H Puller16
01-17-2006 16:09:53
What is the bore of an H when the sleeves are knocked out?
Ken B
01-17-2006 17:14:20
 Re: Farmall H in reply to New H Puller16, 01-17-2006 16:09:53
3 9/16 Been running one for 4 years
New H Puller16
01-18-2006 13:23:29
 Re: Farmall H in reply to Ken B, 01-17-2006 17:14:20
What pistons did you use?
Ken B
01-19-2006 16:01:18
 Re: Farmall H in reply to New H Puller16, 01-18-2006 13:23:29
I used 560 lp but they don't come all the way to the top .
ChadS
01-20-2006 04:04:18
 Re: Farmall H in reply to Ken B, 01-19-2006 16:01:18
Find a set of 3-9/16 bore Super H pistons or C-169 from the early 300. Ken B, thats a half inch difference in compression height H is 2.5 a 560 is 2.02. Did you lengthen the rods or something? Chad
