PULLING TIRES
Farmall 400 pul
03-17-2002 17:49:08
I have a set of 16.9/38 armstrong long bar,long bar tires that are woren but does not have a sharp tread. My neighber has a set of long bar, short bar 15.5/38 that are road wore and has a very sharp tread would the 15.5/38 with the long bar short bar tread that is sharp be better on my farmall 400. I am 19 years old and starting to tractor pull and need some advice. Most people pull with long bar long bar. Theses 15.5/38 long bar short bar tires are very sharp would they be worth buying.
Farmall 400 puller
03-18-2002 18:10:54
 Re: PULLING TIRES in reply to Farmall 400 puller, 03-17-2002 17:49:08
Thank you all for your advice.
Mike S
03-18-2002 15:14:36
I have 15-5-38 on my John Deere G they are long bar,short bar armstrongs road wore. Not much tread on the back side and about 1/2 to 3/4 inch on the front side. These tires work excellent. Some tracks it will kill my G in the 7500 pound class in first gear.
Greg H.
03-18-2002 10:02:38
Personally I'd check the heighth and count the number of bars you'll have on the ground at once. If it were me, and I already had the armstrongs on, I'd find a place to tie the front of my tractor down {carefully}, and gengerly spin my 16.9's backwards on conctrete to sharpen them up, then you'd have the best of both worlds in a sharp set of armstrong tires that are taller than the other set. If the long bar short bars are 8 ply sidewalls, they might not be too bad. I tryed a set of 6 ply's once, and they buckled bad, I would loose draw bar, and then I'd spin out, all this with 17 pounds of air in them. It's up to you, but like others have stated I like the tallest tires the tractor will spin out with. good luck in your pulling. Greg H.
buckmaster 700
03-18-2002 09:58:13
use your armstrongs never the less you will have more rubber on the ground the long bar short bar will dig to deep thus you have a big pile of dirt infront of the sled to pull
Roy
03-18-2002 01:03:30
Never had much luck with long lug short lug tires on a pulling tractor.
Roy
03-18-2002 01:03:11
puller
03-17-2002 18:12:43
When looking tires you also need to look at height because that will change more than the bar setup will and not all brands are the same. Ken
paul
03-18-2002 02:57:27
 Re: Re: PULLING TIRES in reply to puller, 03-17-2002 18:12:43
I have a set of armstrong L/B S/B tires that I've pulled and they work OK.Not as good as FS but if the price is right try them.Good luck Rookie
