Massey 44 surge
Kevin
01-16-2006 09:14:20
When i fire up my massey harris 44 it kinda surges for a few seconds. I notice the rod going to the carb wich i believe comes from the governer plunges back and forth therefore cuasing the surging. When i go from near idle or a slower RPM to a sudden jolt up to full throttle she does it too. Anyone know why or have any theories that might help me?
acwc
01-16-2006 18:24:13
 Re: Massey 44 surge in reply to Kevin, 01-16-2006 09:14:20
my 44 did that when I had to week of a gov spring. Try a little heavier spring. Or you might not be getting enough fuel.
Kevin
01-16-2006 19:20:45
 Re: Massey 44 surge in reply to acwc, 01-16-2006 18:24:13
Im almost going to go with not enough fuel on this one now that you mention it as my plugs are a really light whitish brown color. Its got a denny carb on it, should i call and try to deal with him to get the problem fixed or think i should try to tinker with it myself?
acwc
01-17-2006 03:35:44
 Re: Massey 44 surge in reply to Kevin, 01-16-2006 19:20:45
better make sure you have enough fuel getting to the carb and then try to adjust it. does it straighten out when under load? if it does sounds like spring.
Kevin
01-17-2006 12:53:44
 Re: Massey 44 surge in reply to acwc, 01-17-2006 03:35:44
It does straighten out under load i believe. Its been so long since i last pulled it i could be wrong. Do you know were i can get a new gov spring for the 44? Id like to get some more rpm out of her and maybe a quiker rev to while im doing it. I believe the rule is 1650 rpm for div 2 and 1800 for div 4. I pull div 2 but maybe 1700 or 1750 will work.
acwc
01-18-2006 03:30:46
 Re: Massey 44 surge in reply to Kevin, 01-17-2006 12:53:44
your local hardware store match one up that is the same length but a little stiffer.
Kevin
01-18-2006 16:55:03
 Re: Massey 44 surge in reply to acwc, 01-18-2006 03:30:46
Is the spring im replacing the big one conecting the two rods? Will a stiffer one give me more rpm or a quiker throttle response? I really dont know much bout how the masseys are goverened so i apreciate any help.
acwc
01-20-2006 09:27:22
 Re: Massey 44 surge in reply to Kevin, 01-18-2006 16:55:03
yes the one connecting the rods. It might give you more rpm and should make the gov respond quicker. just dont go to stiff
