jd a rough idle
jd plowboy
01-16-2006 08:57:20
i have a jd a with a dtlx 72 carb. it runs fine except at idle. it will idle perfect if you pull choke out a little. if you push back in it will idle rough off the governor. how can i fix this. thanks in advance.
G/MAN
01-17-2006 13:31:41
 Re: jd a rough idle in reply to jd plowboy, 01-16-2006 08:57:20
Sounds like it could be a problem in the carburetor's idle circuit starving it for fuel, and it requires just a touch of choke to fatten it up enough to run correctly. You might also check for vacuum leaks.
BushogPapa
01-16-2006 19:08:57
You may just be "one click" off on the idle mixture...they can be kind of particular..!!
Ron..
JDTH
01-16-2006 10:34:24
Sounds like one or more of the passages in the carb are plugged. Take the carb of, and clean all of the passages.
