best cam grinder for stock / a little more
johndear
01-15-2006 20:37:07
Who is the best cam grinder for a JD cam on a virtually stock motor? Need my rusty cam and lifters touched up for a rebuild. Want a grind just "slightly" over stock. Nothing radical as motor is basically stock with about 8.5:1 compression.
Thanks,
dp in nd
01-28-2006 15:34:20
 Re: best cam grinder for stock / a little more in reply to johndear, 01-15-2006 20:37:07
berrycam.com I got a card with the cam.
52 A Boy
01-15-2006 21:35:56
I had my B cam ground by Roberts in Iowa and he did a great job, now this is just my opinion but i would recomend him to anyone for this or carb work, heres his shop number 712-262-5311, call him and tell him what you want to do, he can set you up right.
Hope this helps,
52 A Boy
johndear
01-17-2006 15:40:55
 Re: best cam grinder for stock / a little more in reply to 52 A Boy, 01-15-2006 21:35:56
A friend had Robert's do a cam for a JD. Was a little dissapointed they didn't get a cam card, specs, or degreeing information from him. Tractor runs fine, but who knows what grind he got?? Hoping to find someone that grinds them in-house and can tell me what they plan to do (in degrees and lift).
Thanks,
