Ford 741pulling
Gene Chauvin
01-15-2006 10:06:43
Has anyone pulled with a Ford 741? If so what weight class are you pulling? I am restoring one now and hoping to pull in the 3000# class.
Any suggestions on how to get the most HP out of this engine??
Gene Chauvin
01-22-2006 10:58:36
 Re: Ford 741pulling in reply to Gene Chauvin, 01-15-2006 10:06:43
I pull with Ford 900 4000# and 5000# classes now and finish in the top 3 just wondering how the 700 will do. Different transmission (4spd) and with the smaller block engine
CLIFF S
01-15-2006 16:20:56
I know 2 Guys that pull FORD 700 series tractors, 1 is in central PA and pulls 3000,3500,4000lbs classes and dose great, and the other is Arnold Martin of Michigan that Pulls with NATPA and I can say he is as Tough as any one!!!
J. Banet
01-15-2006 17:38:12
 : Ford pulling in reply to CLIFF S , 01-15-2006 16:20:56
The 600 and 700 series tractors are the same. The only difference is the 600 is a wide front and the 700 series is the narrow front. Plane the head down and put in bigger valves. Port the intake and head along with some bigger jetting on the carb.This will get you started untill you can bore it out to gain some cubes. Check the results from Wausen oh. in Nov. on the NATPA site and you'll see all the Fords did well in their classes.
CLIFF S
01-16-2006 07:54:42
 Re: : Ford pulling in reply to J. Banet, 01-15-2006 17:38:12
I agree with J, I was at Wauseon and Arnolds FORD Beat ME!!!
