cam grinds
Custom King
01-15-2006 09:54:48
Anybody got any funky cam grinds for a large cube non turbo gasser.No limit on rpms,4000 rpms with stock and puller grinds, not to say thats the problem, building new intake.Got 2 different cams done by Berry Cams. Any ideas on a grind to make it come to life? Something that works. Thanks.
Strange Brew
01-15-2006 10:48:08
 Re: cam grinds in reply to Custom King, 01-15-2006 09:54:48
What are the specs you have on your "puller" cam right now? What is the problem with your tractor, need more rpms? Is it sluggish? What kind of compression you got? Hard to suggest a grind without some of that info.
Custom King
01-15-2006 13:24:32
 Re: cam grinds in reply to Strange Brew, 01-15-2006 10:48:08
333 lift, 240 duration, 272 seat duration.Tractor is sluggish.Could never open throtle all the way it would miss and pop, may be to rich on high end, run better when leaning down, real good with a little NOS. Rpms no different with stock cam 70 deg. less duration. 9.1-1 com. 210 psi. It sounds real good when you whind it up,it wants to go but it"s just kind of dead.
