Tires
turbored
01-13-2006 14:08:20
What is the best pulling tires
Ohio puller
01-14-2006 18:15:04
 Re: Tires in reply to turbored, 01-13-2006 14:08:20
I have and like my firestone F&R 151's. I have done very well on many types of tracks with different tractors, HP, and weight classes. Mine are not cut so I don't know how they would pull cut. Works for me but I also know there are other brands on other tractors that work well. There are many things to take into consideration when it comes to tires and wheels. My advice is try to borrow different types ( if you can ) till you find what works for you. Also look at the classes and area you will be pulling in and see what seems to be working the best. Good luck and hope this helped.
buickanddeere
01-14-2006 11:20:00
Track composition, weight class, HP, speed, cut or un cut?
770
01-14-2006 10:57:58
What about BF Goodrich 45 degree???
turbored
01-14-2006 09:31:15
Thanks!!
Mcred
01-13-2006 22:06:54
Firestone 23 degree angle
Dane in PA
01-14-2006 09:55:30
 Re: Tires in reply to Mcred, 01-13-2006 22:06:54
yea, I would have to agree with what Mcred said. I had Firestone 23 degrees on my JD B that worked well. I am looking for a set for my A now. they're a good tread
Pullin
01-13-2006 19:39:13
As a rule of thumb, you usually have the odds in your favor with Armstrong's or Firestone's. But that's not to say you can't make others work also.
