Pulling Clutches
Farmall H Pulle
01-12-2006 17:51:07
Does enyone have eny good clutchs to recomend. I have a Farmall H that im getting some engine work done to and i looked at the clutch and it getting pretty wore out . Does enyone know where i can get a good pulling clutch?
Thanx Miles
Mike S 806/H
01-13-2006 11:23:31
 Re: Pulling Clutches in reply to Farmall H Puller, 01-12-2006 17:51:07
Fort wayne clutch & drive (260)484-8505, They can build what you need and get to ya fast and resonable! Ask for Scott
REDWHEELS
01-12-2006 18:23:42
I had HY CAPACITY build my clutch. It is a 6 pad ceramic disc and the pressure plate is Super H.
I used the flywheel from a Super H or 300 and the 10 inch diameter set up. Holds good with 60HP.
ChadS
01-16-2006 14:38:55
 Re: Pulling Clutches in reply to REDWHEELS, 01-12-2006 18:23:42
350 flywheel, with a H starter ring, 460 pressure plate and a super H clutch disk. That will make a 10.5 diameter clutch, that can hold 70+ using IH parts. ChadS
