MH 55 build up
Masseyharris333d
01-11-2006 20:37:06
Looking to build a MH 55 for pulling. How far can you stroke it and still keep stock rods and hop up pistons. i am looking for aprox. 120 HP Does anyone know where i could buy a crank if needed. How much do you think it would cost for 120HP
Kevin
01-14-2006 15:14:14
 Re: MH 55 build up in reply to Masseyharris333d, 01-11-2006 20:37:06
I know someone that pulls a MH 55 in the 6500 lb class and i beat him with my 44. Id say pass on the 55 project and go get a 44, alot easier to get more juice out of.
Masseyharris333d
01-15-2006 08:03:50
 Re: MH 55 build up in reply to Kevin, 01-14-2006 15:14:14
what do you have done to your 44
Kevin
01-15-2006 12:21:50
 Re: MH 55 build up in reply to Masseyharris333d, 01-15-2006 08:03:50
My 44 is up to 349ci if you want to talk more about set eup email me, mu email should be open.
Masseypuller
01-13-2006 12:55:58
I hate to be the bearer of bad news, but your 55 is better off restored for show rather than pulling. The parts are scarce (read "expensive"), the cylinder head is actually worse than a 44, the bottom end does not have much room for stroking because of the starter "bump" cast into the block, and the block is so tall that you cannot order custom pistons to fit.
To get 120hp, you will need to look at spending between $9000 to $10000, if you can even find someone to do it...
Been there, done that, bought the t-shirt.
Now a 44 on the other hand has much more potential...
Regards,
Masseypuller
Masseyharris333d
01-14-2006 14:46:39
 Re: MH 55 build up in reply to Masseypuller, 01-13-2006 12:55:58
Where do you pull and what weight class
Masseypuller
01-17-2006 09:45:15
 Re: MH 55 build up in reply to Masseyharris333d, 01-14-2006 14:46:39
1957 MH 444 "Triple Play"
590 cubic inch H260 based engine. Engine is designed and built to run 2050 RPM high idle.
4500 to 6500 "open" Antique or Pro Stock Antique
Mainly Central Indiana (until the bugs are lined out)
Masseyharris333d
01-17-2006 19:30:24
 Re: MH 55 build up in reply to Masseypuller, 01-17-2006 09:45:15
how much do you have invested. what kind of hp are you getting.
