M carb ?
SUPER MTA PULLE
01-11-2006 10:24:36
Just how mportant is the idle jet that tiny brass tube projecting from the fuel bowl?I have a couple of carbs otherwise pretty decent which some careless individual has broken off.i would like to salvage these if possible.Will they run worth a hoot?A real clean idle is not necessary on a puller and it might psyche out thje competition.Thank you.
SUPER MTA PULLER
01-13-2006 10:50:53
 Re: M carb ? in reply to SUPER MTA PULLER, 01-11-2006 10:24:36
IT is CAlled the idle jet in the I anT manual.It is not the main fuel discharge tube which everyone keeps talking about drilling out.I think it is where the idle fuel mixes with air.
seem to me like it would only affect the idle.Thsnks again
some carb knowledge
01-12-2006 15:30:25
Sounds to me like you want this feller to ruin his carburetor. This tube you are refering to is the fuel tube. The engine would NOT run with out it. Maybe you pull against him and this is your only chance winning.
F'in farmall
01-11-2006 20:29:26
If i'm thinking about the right tube, it runs from the bowl up into the throat of the carb in front of the venturi. if this is for a puller, cut that damn thing out, fill it in with sone JB weld and smooth it out with a die grinder. you'll gain a little bit of flow out of your carb.
AC
01-13-2006 15:52:12
 Re: M carb ? in reply to F'in farmall, 01-11-2006 20:29:26
Seems that might LEAN up the mixture a wee bit..why don't you try doing that to your backside, and see how it works..AC
