welding sleeves
mshultz
01-11-2006 07:09:23
Have an IH 281 block with two cracks in #4 cylinder. Have been advised to bored out to accept a sleeve, sleeve it, and have the sleeve welded in at both top and bottom.
Anyone know of a reputable place to have this done in or around PA?
Any good/bad experiences with this??
Thanks!
steelperformance
01-15-2006 10:30:24
 Re: welding sleeves in reply to mshultz, 01-11-2006 07:09:23
If you need a block bored and sleeves welded in I have a furnace to heat the block and weld the sleeves in.I can also repair heads and manifolds that are cracked. 231-584-3322
buickanddeere
01-11-2006 20:21:15
"Muggy Weld" if you want to weld or silver solder sleeves in.
jd b puller
01-12-2006 04:50:08
 Re: welding sleeves in reply to buickanddeere, 01-11-2006 20:21:15
Can someone elaborate on this "Muggy Weld"?
Thanks,
buickanddeere
01-12-2006 16:57:34
 Re: welding sleeves in reply to jd b puller, 01-12-2006 04:50:08
Link
RKM
01-11-2006 16:06:09
Any good automotive machine shop should be able to bore the block and press a permanent sleeve in the cracked cylinder. There is no need to weld anything.
Jim in OH
01-11-2006 10:27:48
I would think that any typical engine shop could handle this one, nothing special required... I had a Ford 352 V8 with a cracked cyl wall... took it (dis-assembled)to machine shop with the old piston... they bored, "dry" sleeved it, and rebored/honed to the old piston and there were no welds that I saw. It was "cheap" and it ran fine after that with no leaks... Jim
JRD(VA)
01-11-2006 07:44:28
If youre not too far from Frederick, Md., Automotive Parts & Machine, Dave Featherstone, 301-663-8866, specializes in head and block repair. Fixed an M head for me, head was BAD!, did a great job.
Dieselbear
01-11-2006 12:09:58
 Re: welding sleeves in reply to JRD(VA), 01-11-2006 07:44:28
GIVE ME A BREAK, They have screwed up more stuff than enough, and he knows how to charge!! Not just my stuff, ask the mechanic at the local Agco Dealer. Glenn
CLIFF S
01-11-2006 07:37:48
I know someone that can do it and tell you more about it, Give me a call, Cliff
