stromberg carbs
es
01-10-2006 13:42:59
what tractor did a stromberg nar9 come off of
Hitt Motorsports
01-11-2006 20:24:56
 Re: stromberg carbs in reply to es, 01-10-2006 13:42:59
The exact aircraft engine was a Pratt & Whitney 985 cube 9 cylinder radial air-cooled. Peak power was about 450HP at 2400 RPM.
I have a number of these on the shelf here for pullers. They came with either a 2 3/4" venturi or a 2 5/8" venturi. Typically you need to have at least 400 cubes at 5500RPM or higher to make the NAR9 work correctly. An easy calc to get you in the ball park is to compare the 985cube X 2400RPM to your CID X RPM. They are a nice carb and have a mixture control lever to tweak the air/fuel ratio. The NAR7 (2 1/4" venturi) is a better fit for lower RPM, lower cube motors. I have some of these too.
Need a carb
01-12-2006 17:56:06
 Re: stromberg carbs in reply to Hitt Motorsports, 01-11-2006 20:24:56
How do we get a hold of you?
Hitt Motorsports
01-12-2006 18:14:23
 Re: stromberg carbs in reply to Need a carb, 01-12-2006 17:56:06
651-251-3857
Cody
01-11-2006 06:05:03
They are off of late 30's vintage radial aircraft engines. And some crop dusters used them, that is where the agricultural connection comes from.
David
01-10-2006 14:39:23
The kind that flys (literally)!
