Need a little info on a 1066
Josh Land
01-09-2006 21:55:24
Hey yall. Got a 1066 that I wanna pull some in the farm stock class. Im not wantin to go all out and make it a full blown puller, just lookin to have a little fun on the weekends. So is there anything else i can do to squeeze a lil more power out of it? Right now ive got the fuel screw turned out 11 turns and thats about all shes got. Nice power increase, but just wondering if theres any other mods i can do. Some people say to throw a lil alcohol or tranny fluid in the fuel tank when I go to the pulls, but i dont wanna end up hurtin the motor. The tractor is used some on the farm so I cant do a whole lot to it. Just lookin for some mods that can be done fairly easily. Thanks in advance for your replies.
Josh from Lancaster Ky.
Sheepdog in NE
01-10-2006 18:37:15
 Re: Need a little info on a 1066 in reply to Josh Land, 01-09-2006 21:55:24
The pump should go to a pump shop and tell him what you told us. Sometimes backing the screw out won't affect the stock pump. He can make it so you can pull one day, turn the screw and farm that afternoon. Also a 3lm turbo will wake him up. A little oil will help but you will not notice it from the seat.
minnesota red
01-10-2006 19:55:27
 Re: Need a little info on a 1066 in reply to Sheepdog in NE, 01-10-2006 18:37:15
that would also work by simply swapping pumps,get a model 100 11MM with gov set at around 4000 and play on the weekends and farm during the week.
did this for years,after about 4 times you can switch pumps and injectors in about 25 minutes.
4010 puller
01-12-2006 06:49:40
 Re: Need a little info on a 1066 in reply to minnesota red, 01-10-2006 19:55:27
If you look hard enough, you can find a Schwitzer 3lm466 turbo with the 241 exhaust housing for ~$300. These are pretty good turbo"s, a far cry from stock TO4 or a 3ld.
