Top cut tires in stock class
Flogger
01-09-2006 20:24:21
Well I understand some of the local NC pulling associations are going to top cut tires in the stock classes. I'm actually glad to see it. There's been a lot of disputes regarding "road worn" tires as opposed to intentionally "cut" tires, some clubs allowed them and some didn't. I think it will level the playing field, especially when the track isn't that great. 'Got as feeling a lot of doctored tires were slipping through before anyway. 'Hopefully it will settle some of the disputes and give some of the more honest pullers a better chance to be competitive. I realize it's not necessarily a new topic on this board, but wondered what some of you gentlemen and lady pullers might think in regards to it. In my opinion new tractor tires aren't exactly cheap and it's hard for me to justify replacing a set just because the front edge of the cleat is rounded off a little.
No Cuts Wanted
01-10-2006 15:45:15
 Re: Top cut tires in stock class in reply to Flogger, 01-09-2006 20:24:21
My opinion is that if you start allowing cut tires, the normal out of the field or hobby tractor will just have another strike, our local clubs get quite a few hobby pullers that use their tractors on the farm. Cut tires are expensive and have to redone occasionally to keep them sharp. It isn't hard to tell cuts, and once the puller is told the tires aren't legal then he will either change them or stay home. If you want to run cuts run Div 3 or up.
MHO Richard Peoples
Mike Aylward
01-10-2006 09:13:16
I have always wondered why clubs fear cut tires so much. If they allow top cuts they are pretty much admitting that it is only the front cut they fear. Why not just allow cut tires and be done with it? Instead of doing a lot of infighting, level the playing field and get a set of cut tires. I"ve always wondered about that, but I wonder about a lot of things someday..:) Mike
JDRooster
01-10-2006 05:45:14
Flogger, Would you give me a definition of "Honest Puller". Are you sure that you are not talking about two different subjects?
Flogger
01-10-2006 08:55:34
 Re: Top cut tires in stock class in reply to JDRooster, 01-10-2006 05:45:14
'Rooster I think I said "more honest" not honest...
pink puller
01-10-2006 16:20:09
 Re: Top cut tires in stock class in reply to Flogger, 01-10-2006 08:55:34
LMHAO!!!!!
WILDMAN H
01-10-2006 04:45:15
FLOGGER IS THAT RULE AS LONG AS THE LEADING EDGE HAS NOT BEEN CUT?
Flogger
01-10-2006 13:16:22
 Re: Top cut tires in stock class in reply to WILDMAN H, 01-10-2006 04:45:15
Hey WILDMAN,
Yes from what I understand the leading edge of the cleat cannot be altered. 'Got those wicked farmalls ready to go for spring?
WILDMAN H
01-11-2006 04:31:34
 Re: Top cut tires in stock class in reply to Flogger, 01-10-2006 13:16:22
FLOGGER NOT COMPLETLY STILL HAVE A FEW MINOR REPAIRS AND BANDAIDS TO PUT ON THEM.
pink puller
01-09-2006 20:46:37
Hey Flogger! I am looking forward to pulling with cut tires mainly because of the bite. I will have the expense of another set of rims and tires, and the headache of changing over for the clubs that have not switched to cut tires, USAP pulls with cuts so it will help out when we pull with them, hard to compete otherwise. Hopefully one day all the clubs will adapt their (USAP) rules, they are very fair and seem to have postive feedback from the pullers. Just my opinion.
Flogger
01-10-2006 13:23:03
 Re: Top cut tires in stock class in reply to pink puller, 01-09-2006 20:46:37
pink puller,
What kind of rules does Northbrook go by? Do they have all their pulls at the same location and where? 'Been hearing about the Northbrook pull for years but never have made it to one.
