G1000 deisel puller
DoddsRacing
01-08-2006 09:42:24
Can you put deisel heads on to the 605 or the 800 blocks? Also what cranks will fit the deisel block to get a longer stroke?
RMW
01-08-2006 12:52:02
 Re: G1000 deisel puller in reply to DoddsRacing, 01-08-2006 09:42:24
I think the heads will fit the biggest problem will be fuel system.
Dodds Racing
01-08-2006 15:46:34
 Re: G1000 diesel puller in reply to RMW, 01-08-2006 12:52:02
We are having the pump and injectors done and are also running larger lines. I see a lot of LP gas engines going with huge bores and strokes,but no diesels . Is it the cost or is it something I have not found out yet?
