Powerblock sleeve
JDJOE
01-04-2006 07:29:03
I found a powerblock with a bad sleeve. Where does one get a new sleeve? Or can I have a chunk of well casing turned in a lathe to have a new one made? How does the old one come out? Thanks.
jd b puller
01-05-2006 17:20:11
 Re: Powerblock sleeve in reply to JDJOE, 01-04-2006 07:29:03
JDJOE - send me your phone number and I'll see if I can help you out.
jd b puller
01-04-2006 15:08:10
Like G/Man said, what do you mean "bad". Broken, cracked or just pitted.
Which block is it? If it's a B, you can bore it 0.125 and put a 5.125" piston in there. If it's an A, you can bore it 0.125 and put a 6.125" piston in there.
If it's a G, I don't know what your options are.
If it's broke, and it's a B, put two new 5.25" sleeves in it.
want to know
01-05-2006 22:46:17
 Re: Powerblock sleeve in reply to jd b puller, 01-04-2006 15:08:10
are you putting in 5.250 outside diameter sleeves or bore size of 5.250. if bore size how think are the sleeves
jd b puller
01-06-2006 04:45:00
 Re: Powerblock sleeve in reply to want to know, 01-05-2006 22:46:17
"Want to know" - You can resleeve it to 5.25" piston size. That'd be a .125" thick sleeve, so 5.5" OD sleeve. You can overbore the stock bore to 5.125" without resleeving. I think his sleeve is broken, so you might as well replace both sleeves and put the 5.25" piston in there.
JDJOE
01-04-2006 18:06:26
it's a B block. It had a stuck piston, I took it to a machine shop to have it pressed out. They pressed the end of the sleeve from the block. They refuse to do anything about it.
G/MAN
01-04-2006 13:20:29
What do you mean by "bad" sleeve? I believe it's possible to put a sleeve in the sleeve, just like sleeving the bore in a regular parent-bore block.
