More Power Suggestion for JD?
Kirt K.
01-03-2006 17:46:09
I am looking into getting more power into my 1941 John Deere B. If I were to take off the breather, would that allow more airflow into the carb to increse power a small amount. I really don't want to tear down the motor again, since it was recently Overhauled. Also, for a little more power, could it handle airplane fuel? Or, maybe, is there a high performance carb out there???
buickanddeere
01-06-2006 09:10:34
 Re: More Power Suggestion for JD? in reply to Kirt K., 01-03-2006 17:46:09
E-85 fuel might make a little more power by chilling the air-fuel mixture? Without making the engine a better air pump the HP won't happen. If she has enough snort to spin out is 1st gear, work on getitng more traction.E.g. trick tires, better balance etc. Nothing makes owners of modified tractors madder than seeing some old stock tractor place in the top three while still covered with cow cr*p.
G/MAN
01-04-2006 10:27:21
Higher octane fuel, such as "airplane fuel" is not going to gain you any power, and may very easily cost you power. Higher-octance fuels are more resistant to uncontrolled ignition, or "spark knock". This is because they are harder to light off. Octane has nothing to do with the energy in the fuel, which is what controls how much power can be gotten from the fuel. Making the engine "run hotter" is going to heat the intake charge more, even with a cold manifold, and will once again cost power - the hotter the mixture, the less dense it is and there is less oxygen and fuel present.
Jak
01-04-2006 09:06:19
Along with adding a dry air filtration system,get in touch with CBS Performance in CO and order a Pertronix ignition with the coil and put it in.Then get you a set of GOOD plug wires and open up the plug gap,get some fire in them holes.You possibly can add some timing after that(advance it).You should get all she's got w/o tearing into the hard parts.Jack(TN).Good luck Kirk.
BushogPapa
01-03-2006 21:16:38
Gasoline Pistons (or even up to 7:1) would make a big difference.... At the same time maybe you can clean up the intake runners, the port-matching between the intake and head, and do some nice valve work to increase air flow... I think the Gasoline pistons are the most cost-effective way to go... It might get you into the 20+ HorsePower range at the Drawbar.. The Late Styled "B" was about 24.5 on the Drawbar and 27 on the Belt.. Ron..
jd b puller
01-03-2006 20:01:45
Drew"s right. Octane does not MAKE power, it LETS you make power. Engines are more prone to detonation when you increase compression ratio, advance the timing, increase the RPM"s. Increasing each of these within limits will increase HP, but if you don"t increase the octane, it will knock.
Drew
01-03-2006 18:43:25
Using octane booster or aviation fuel will not increase horsepower. Octane is how resistant a fuel is to detonation. As long as its not spark knocking, you do not need more octane.
As for the air breather, there can be some horsepower there. I recently dynoed a John Deere 60 and it gained 3hp just by taking the oil cup off the bottom of the aircleaner. Your results may vary. If you can come up with a Heisler or Johnson manifold, that may help a little too.
Dane in PA
01-03-2006 18:03:08
i've never heard of using airplane fuel, but i was told before to use high octane booster to make it run hotter. i never used it though because my JD B always did fine without it. you can get it at pepboys or autozone or a car parts store, if you're interested.
