super m engine rebuild
super_m
01-03-2006 16:54:18
im rebuilding my super m motor.It has 4 1/8 Firecraters. 8060 Head was ported,polsihed and milled .It has a electronic ignition,with a hot coil,wires and plugs and a K&N air filter.How much HP should i have? I have 15.5x38's.Will I be able to do any good in Div 2 up to 6500 on good tracks if I keep it in low gear?
TWL
01-04-2006 13:22:18
 Re: super m engine rebuild in reply to super_m, 01-03-2006 16:54:18
I would guess around 60hp,I would think you would do better in 5000.
B BARENIE
01-04-2006 04:10:55
6500 LB DIVISION (2) WITH TOP CUT TIRES, WILL PROBABLY TWIST THAT SETUP ALL TO PIECES.
Not being an a@@ but the majority of tractors in division (2) have been warmed up quite a bit !
