IH 806 LP piston pic
Superhooker
01-02-2006 17:16:17
The depth of the crater is approximately 1/2". The height of the bump is approximately 1/8". Are these the desirable LP pistons or standard firecraters? I need to bore the block to eliminate rust in the bore so I'll need new pistons. I want to maintain at least the same compression with stock stroke because I may put this engine back on propane at some time. The head (383666R2) has a very shallow combustion chamber. About 5/8" on one side and 1/4" on the opposite side. Block bore is 3.810. What would you do?
ChadS
01-03-2006 09:02:17
 Re: IH 806 LP piston pic in reply to Superhooker, 01-02-2006 17:16:17
They are standard firecraters. You can get bout any size overbore offered. Sounds like a regular gas engine converted to LP. I dont know if IH can still get high altitude,LP pistons for that engine,, I thought I had bought the last set in captivity a few years back,,, Chad
