Head Gasket For A 4 Bore Oliver 77?
Clark W
12-31-2005 17:28:54
Can you guys tell me if there is a head gasket manufacturer out there for a 4" bore Oliver 77 or do you make your own from sheet copper? Or, is there another solution? Thanks in advance.
Chase
01-01-2006 12:33:28
 Re: Head Gasket For A 4 Bore Oliver 77? in reply to Clark W, 12-31-2005 17:28:54
Try Lubbock Gasket Company in Lubbock, Texas. Should be able to find a phone number online. They can set you up with a composite gasket with crimped or drop in fire rings, or a copper head gasket.
stroker 88
01-01-2006 09:51:12
forgot to mention that the last. i will check on the 77, for 66 the felpro set for 3 5/8" and up will handle 4" bore.
Gamitch
01-02-2006 06:35:35
 Re: Head Gasket For A 4 Bore Oliver 77? in reply to stroker 88, 01-01-2006 09:51:12
There is a 3 & 3/4 gasket that will work on the 4" 77 bore. I think it's also listed for 1555.
